Budget friendly 2800 torque converter for aod
    I the cam I put in my 351w calls for a 2800 stall torque converter. Any suggestions would be appreciated. I'm running a aod out of an 85 police car
    I'm thinking about the b&w torque masters 40438. Will this work with my cam it's the comp cams extreme energy, 35-771-8
      dirty dog, pi, circle D would be my choices
        Edge also has a decent rep..........Road Runner might be another option to look at...........
        Rodney Tolleson, me at the track.....future drag box racer!
          I've never messed with an aftermarket torque converter, so my question is would a 10 inch converter bolt right up or does size matter
            The size of the tc is usually dependant on the amount of stall you desire. I used a b&m on my vic, don't recall the size or advertised stall. As long as it will bolt to your year of flex plate & aod you should be good
              Like mitymerc said, if the bolt pattern aligns, you should be good.
              As they get smaller in diameter (usually the stall speed goes up), they use arms outside the converter housing to attach to the original mounting points.
              I had a dirty dog 3200 in my coupe; what a great converter.
                I ordered a 2800 stall from road runner
