Hi all
Due to a family situation my free time has reduced to some unknown negative figure. I've asked questions about this and I've read a lot and I thought I had it all together, but my brain is totally preoccupied and I feel lost again.
My control arm bushings are trashed to the extent that I have dynamically changing wheel alignment and I have an upcoming 1 week family trip (in May, but I still feel crunched for time) out of town in the same car. I really don't want to rip it all apart to do the control arm bushings if I'm just going to have to do the same this summer when I do big brakes. Therefore, the big brake swap is expedited so that I don't a) waste parts and b) re-do too much.
I also just bought my first house, so budget is a factor. Yay!
Sooo...I need someone who is well versed in big brake jobs and general front end stuff to check over what I have and tell me what I need. Easter weekend is my target for getting this done.
Parts that I have. Please forgive model years, everything is "at least" 98-02 but I'm sure I'm going to cause confusion for future people because some of these items are all the way from 95-02...
Parts that are "on the way" (ordered but not here yet)
Calipers will be purchased locally. Directly relevant to pads; same question about pad mounting applies.
Stuff that I don't have that I know I will need, which I'm not sure how/where to buy:
Is there anything I need that is not listed above please let me know.
Also, tech questions:
Of course I'll be taking it to get aligned when it's all done (but it needs to be "good enough" to drive on for a day or two prior, low speed short distance city stuff only).
I apologize for being a pest and probably re-asking questions that have been answered many times...I'm just really all over the place right now and the thought of doing this job is kind of killing me (it's something I've really looked forward to, but other conditions are taking away the enjoyment right now)
Thank you
- 98-02 LCAs (new complete - ball joints, bushings installed)
- 98-02 spindles (junkyard. missing the upper ball joint retaining bolts)
- 98-02 hub/bearing assemblies (new)
- 98-02 caliper brackets (rusty junkyard stuff but it'll do)
- Spindle nuts (new, also have the junkyard ones if for whatever reason I bought the wrong new ones)
- 98-02 upper ball joints (new)
- 98-02 brake hoses (new, both sides)
- Earlier year (95-97?) UCAs with cross shafts and eccentrics/nuts
- Brake fluid
- 16" wheels with tires
- 98-02 Front brake pads. As best I can tell, there is only one mounting type for 98-02 cars. If this is not true I need to know ASAP.
- 98-02 front rotors
- hardware kit - rubber boot things and clips
- The retaining bolts for the upper ball joints in the spindles. Can anyone offer up specs on appropriate bolts or should I take a spindle in to someplace that sells bolts?
- Brake line adapters as I am not currently re-doing my brake lines (if I can at all avoid it).
How does this work exactly? Hard line to adapter to flex line? Or does there have to be another hard line between the adapter and flex line?
- Socket size required for the lower control arm bolts through the frame?
- Will the front springs come out without drama by lowering the control arm with a jack, or is a spring compressor strictly required?
Thank you
