if the car has a trac-lok with the clutches in it, you will need a friction modifier . . should be able to use 80-90 oil in it and add the additive in it . .
i have seen the plastic covers.
there are also aluminum covers.
i remember a plastic cover on a 89 townie.
my preferred install method is with a gasket covered on both sides with rtv.
Nobody else is aware that the oil back there needs changing every few decades either Usually they find out that its leaked out when the rear blows up.
I don't even know what the service interval is on that stuff, but its fairly long. If its never been done, or at least checked to make sure it's full, changing it would not be the worst idea.
