Which year F150 front shocks fit the rear of boxes
    99 2wd front
      Could 2wd be shorter than 4wd? The truck sits lower
        Looks like 96 might work better. I'm gonna stay with what I've got instead of messing with it any more.
          you want the rear shocks from an F150, not the front.
            KYB 565010 looks to be almost an exact match for our rear shocks. only about 1.5 inch longer compressed and extended. It doesn't have a fixed shroud over the rod, but comes with a flex boot. If I continue to have motion sickness issues with the Gas-A-Justs... I'll probably get these. Looks to be a MUCH closer fit than the other options I've found so far. It's listed as 4" lowered... which could be why.
              Stats comparison of the KYB shocks...
              KYB Gas-A-Just KG5521 MonoMax 565010
              Extended Length (in) 20.08 21.54
              Compressed Length (in) 12.32 13.58
              Stroke (in) 7.76 7.95
              Cover Yes Yes
              Rebound Stop No Yes
              Bump Stop No No
              Upper Mount S1 S1
              Lower Mount E1 E2(12x38)
              That rebound stop is the important part for me. Looks like what Thain said about pressing out that shell is right for those E2 bottoms. I may also use the old wasted rubbers from the old shocks if I still have them as spacers to keep the shock body off the axle if needed.
                Just got a green handshake at work for recognition for acts of awesome... so I can get the shocks for $12 out of pocket. Here we go...
                  got the shocks... they're installed... getting that inner shell out is a bitch... but it got done... putting the shock on was interesting... Will post in the FAQ.
