think your shocks are totally spent... try bouncing the car without shocks on it. you'll be there a while waiting for it to stop moving.
front end coil spring orientation
Originally posted by porschpow View Post... Curious, Can you put grease on the mounting spots for the coil spring? Would it do more harm than good?Last edited by IPreferDIY; 10-14-2014, 04:37 PM.
I knew I should have put some grease on the drivers side!!!!
I guess I will coat it with a brush (driver's side) and pre grease it prior to doing the passenger side.
Right, id liek to do it as a rust protection measure"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
if you use a spring compressor like you are supposed to, this stuff is easy. No prying, greasing, cursing, or other issues are involved, provided you don't screw up the compressor placement and wedge it in there.86 Lincoln Town Car (Galactica).
Yeah, I have noticed you need to put the compressor clamps about two to three rings inward (so you are able to get it out) AND you have to make sure the compressor shaft is in the middle of the spring (HARD TO DO!)"To Find yourself, you must first lose yourself"
yeah, you have to play with it a bit to get it where it needs to be. The proper type of compressor actually goes through the shock hole and smashes the spring up against the frame, but I have no clue where you can get one of those anymore. I've been tempted to make one from a regular internal compressor and a longer chunk of Acme threaded rod.86 Lincoln Town Car (Galactica).
They do make standalone compressors, where each one is it's own pair of hooks and you can place as many or as few as you want wherever.
I don't know how it'd all line up doing it on the front end of a panther, but I'd imagine 2-3 of a small one like above would do the job without clearance issues.
those won't fit in the frame. Those are for coilover struts mostly.
The kind i have in mind is basically like this. This is for an older Benz, but same concept. Plate holds into the spring on the bottom, and the frame is what you pull towards. Basically it smashes the spring up into the frame hole and keeps it there so you don't have to screw around with positioning it while trying to line up the lower arm.
coil spring compressor: http://www.autozone.com/autozone/acc...er=555573_0_0_
the plate goes on the bottom most coils you can get into next to the lower control arm.
