I just hit 100,000 miles. Should I change the transmission fluid? I do not know if or when It was last changed. I would say the transmission fluid looks kind of green. I do not see any mettle chunks. The only problems I'm seeing is hard shifting.
My mechanic has a 88 and he flushed his. He suggests I do the same. I'm not sure that's a good idea. I think it might be better to drop the pan.
I hear a lot of mixed thoughts on the matter. What do you think?
