About two years ago I got my 1989 grand marquis and I changed the oil and transmission fluid and when I dropped the transmission pan I found a weird object that no one seems to know what it is or where it goes. here's a few pictures of it. Also my transmission has been slipping a bit lately especially while going up hills and I looked into a TV bushing but mine still looks like it's in decent shape so I don't think that is the problem so I think I might change the fluid and filter and see how that goes. Another question is if it would be better to run it in over drive or just drive? What would be better for the transmission? I also have another problem with it turning off randomly on me while starting to go down hills but it fires right back up as soon as i park it on the side of the road. I'm thinking a sensor but I really don't know I'm a novice at these things. I really would appreciate any input or ideas on what to do.
Unknown piece found in transmission pan.
Dipstick hole plug, just gets shoved down at the factory.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
When was the last time it had a tuneup and a fuel filter.
Replace the TV bushing anyway. When it breaks, the transmission will burn up. They're too cheap and easy to replace to risk the $1500 or so a rebuilt AOD will cost you.86 Lincoln Town Car (Galactica).
Regarding drive/overdrive. I always drive in D and go to OD above 55 mph. Same thing slowing down once below 55 I shift into D. On hills I stay in D~David~
Originally posted by gadget73 View PostWhen was the last time it had a tuneup and a fuel filter.
I put it into drive now and so far the transmission doesn't slip and it changes gears a lot smoother so, wow that helped out quite a bit. I was always told to run it in overdrive by some of my back yard mechanic family for better gas mileage and such but I think I'll run it in drive from now on unless I hit the high way and go above 55 like 87gtvic said.
What is a TV bushing?Originally posted by gadget73 View PostWhen was the last time it had a tuneup and a fuel filter.
Originally posted by Toploader View PostCan someone tell me why it's best to run in D as opposed to OD??
My '86 MGM Tudor has about 87K on her and the car has always been driven in OD as opposed to D.
What will be gained if I start to run in D?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
ok, now this is nuts..........my car does not have a tv bushing........I looked at the rod and the only thing at the end of the rod is a ball that is pressed into some kind of small clip..........no bushing at all.....could this be on the 86 models?
Yep 86's are free of the bushings of death.~David~
