I got my car 4 years and 30000 miles ago. I put generic shocks on straight away to pass state inspection (like the $25 kind).
Since then, I did put poly bushings in the front, new springs all the way around, and airbags to help with my move out west-- during which I loaded up 2000# in back for 900 miles.
The airbags still have 30psi in them since I was warned that deflated, they can pinch and tear. They were the generic $80 set you get to manually pump up for carrying more weight than you should, nothing fancy, no electric pumps or load-leveling computer either.
I've noticed that on certain roads right around 20-30mph it has a nice steady bounce going. It's also a bit boaty-feeling again.
Could my shocks be weakening now, after 4 years/30k miles? Or perhaps the few occasions I overloaded the wagon with weight?
If this sounds right, could you look on rockauto (1990 colony park wagon) and tell me which shocks you'd recommend? I can spend a little extra but don't want to go over $200.
Or is this just the result of airbags in the back, and the unfortunate resonant frequency of 30mph (and I should just suck it up and live with it ).
Alternatively, what ARE the symptoms of frame bolts? Can you do them without a lift or impact driver?
Last I looked some of them seemed gone (no bushing left), some of them seemed ok, some of them I couldn't see (and I wasn't looking too hard, just a cursory check). That was 2 years ago.
thanks!!
-Bernard
thanks!!
-Bernard
