Anybody know the size of the nut on the cross shafts? How about the size of the lower shock bolt. I want to replace while I have them out. Thanks.
Need Cross Shaft Nut Size. Lower Shock Mount Bolt Size
87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,Tags: None
oh, misunderstood.
Uppers are 7/8" NC self-locking. Those need to be replaced or they will creak and walk on you
the shocks will be whatever size nut you have welded in there to make up for the stripped out threads. I'd probably go 5/16-NF. Stock I think is M8xsomething.86 Lincoln Town Car (Galactica).
Thanks Gadget. 7/8 NC? That's a 7/8 nut what is the thread pitch?
the shocks will be whatever size nut you have welded in there to make up for the stripped out threads. I'd probably go 5/16-NF. Stock I think is M8xsomething.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
I knew I had seen it somewhere. I just pulled it up out of the sticky at the top of the threads here in drivetrain/chassis. It says it's a 5/8-18, not 7/8.
Suspension/Brakes FAQ. Please Read First!
If you want any info added, PM me or Duece and we will add it.
Control Arm Shaft Nut Size is 5/8"-1887' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
well, some number of eighths then. i dont remember as much as I thought I did, but I can't remember anything I've forgotten.86 Lincoln Town Car (Galactica).
