My car is sagging in the right rear and I was looking into using some just to get through this ridiculous winter, then new springs when it gets warm enough to work outside again. Anyone have experience good or bad with these between coil spacers?
Rear coil spring lifters
The solid ones you twist-in with a ratchet are the only ones that are 'legal' here in VA, and only for the purpose of putting back to normal ride height.
I'd go for them, they should be easy to find. The kind with threaded rod between two plates look scary to me.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I think you're supposed to put them in 2 at a time, one across from the other, one coil apart. I might have just made that up.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I had to use two of the rubber blocks in one of my rear springs to keep the tire out of my fender. Pain in the ass to installhttp://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalf View PostI had to use two of the rubber blocks in one of my rear springs to keep the tire out of my fender. Pain in the ass to install1987 Grand Marquis LS (GONE!)
1990 Grand Marquis GS
I like to go fast
New springs cost you $80 at Autozone and 30 minutes to change. Raise the body off the ground and place on jackstands, place jack under rear axle, remove 2 lower shock bolts and lower the rear axle and let it hang, pull the springs out. Replace. DONE.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,
Originally posted by Deno McThrash View PostI'm not familiar with them, what do they look like?http://secondhandracing.com/Home.aspx
yeah what he said , but go to o reillys
Originally posted by 87stars_stripes View PostNew springs cost you $80 at Autozone and 30 minutes to change. Raise the body off the ground and place on jackstands, place jack under rear axle, remove 2 lower shock bolts and lower the rear axle and let it hang, pull the springs out. Replace. DONE.sigpicTHE H.I.D MASTER
87 mercury grand marquis
88 crown vic lx
89 mercury colony park ls (sold)
89 mercury grand marquis (sold)
00 ford crown vic lx hpp
03 mercury marauder aka punisher (sold )
