Anyone replace the solid Police style upper "A" frame bushings with the civilian type rubber bushings? I know you have to change out the entire "A" frame, as the rubber bushings won't fit in the Police style "A" frames... Anyone ever done this conversion?
I think mine are starting to finally wear out, and I don't think the replacement bushing kits are still available... (It only has about 250,000 mile on it! ) I'm going to try to put it up on a lift this week sometime, and check the bushings and the body mount bushings as well... and see if I can find where the "thumping" noise is coming from...
*** It sounds like a loose upper shock mount, which is bumping up and down when you go over small bumps... Checked the shocks, the sway bar bushings... Nothing loose.... Driving me nuts!!!
