After driving my 89 Gm a little bit and put it in park it always makes a "buzzing" noise underneath the car.. only happens when i put it in park.. Buzzing automatically stops whenever i put it in drive/reverse & even neutral or just turning the car off completely makes it stops.. is this common for these transmissions? assuming it is the transmission
AOD Transmission Buzzing?
Good to know. My '87 CV makes the buzzing sound as well. I always thought it was something emissions-related (evap system or EGR) but never suspected the trans. Ford transmissions love to make non-failure-related noise - the '77+ C6s (Mercon instead of Type F) like to whir in park/neutral, and apparently it's the sprag gear/clutch. They will make that noise for years and thousands of miles without affecting driveability. Then there's the classic first gear whir that we're all familiar with (C6, AOD, 4R70W and many others I'm sure).RyPow
1987 LTD Crown Victoria LX sedan - The "Sand Box" - 73K, towing package
1987 LTD Crown Victoria LX Tutone Tudor - '96 Explorer 5.0 + 5spd swap in the works
1985 Lincoln Town Car Cartier - previously owned by "navguy12" from thelincolnforum.net
2007 Lincoln Town Car Signature Limited, 102k, daily driver
2006 Mercury Grand Marquis LS, 115k, winter beats
1977 Lincoln Continental Town Car, 42k
2012 F-150 5.0L 4x4, HD payload pkg (towing/hauling)
2015 Toyota RAV4 XLE AWD (better half's)
yeah mine does it too. Apparently its also related to high-ish TV pressure, but considering that low pressure can smoke the clutches its a small thing to put up with.86 Lincoln Town Car (Galactica).
Yeah mine does it sometimes too and has survived 10,000 miles of my hooning (and presumably a good portion of the other 90,000 miles before that) with the tranny still acting nicely otherwise. If I remember right, my dad's old Explorer even did it sometimes.
