What can I pull off this?
    What can I pull off of this that will fit my '88? Like his do I convert that VIN into what axle it has. It has a rear stabilizer bar. Is this old enough to have the same mounting points as mine or was the axle updated with the body? I'm gonna be pulling the intake for a spare and the overflow tank/washer fluid reservoir. Also the exhaust manifold (has the "Lincoln logs) but what else? Car is getting scrapped by a friend, and he said I can have what I can pull.
    '88 Lincoln Town Car '78 F250 Hi-Boy
    '80 XS850 '80 GS450 '82 XJ650 '81 XJ650 '81XS850 '82 XV750
    So it's a 90 Town Car? Grab the exhaust manifolds, fan shroud, steel bumpers are 1 year only, may be worth grabbing to sell. Sway bar mounts differently so it's a no go unless you cut the brackets off and weld them to your frame. Axle will work, Y code is 3.08 open, nothing special there. (I think 92 is when they changed the axle codes)
      Yes, '90 town car. Sorry, should have specified that. The bumper covers are pretty bent up, so I'm assuming the bumpers are as well. But I'll take a look tomorrow again when its light out. And darn, was really hoping it had a trac-lok.
      Now from what I understand, the 5.0 block in the '90 was made to mate to the newer AODE, correct? So its the same bolt pattern as a 4.6?
        no. same old aod pattern. the 302 never had the mod motor bolt pattern.
        +1 fan shroud and tank
        +1 exhaust manifolds (Lincoln Logs)
          Nope, that just has a typical AOD. If you want you could grab that too.
