I hooked up the p/s cooler, and ran the return lines first, while it was easy to get to.
P/s box
And then finally, the high pressure line. It took a litlle bit to figure out how I wanted the line to run, but in the end I'm pleased with the way it came out. I filled the reservior, and started the car up. It took about 10 minutes to get completely bled out. After It was bled out, and I couldn't find any leaks anywhere, I reinstalled the air cleaner/intake tube bracket, and assembly. Food for thought. Don't use your remote start, and then try to turn the steering wheel!!!. I thought I screwed up royally, until I saw my keys on the radiator support.
The steering definitely feels different. I'm pretty used to my car, but it really screws me up if I drive something with a stock box or go back to my car after driving a stocker for a bit.86 Lincoln Town Car (Galactica).
So..if ya still remember.....What size were the lines. 5/16 or 3/8?~David~
hmmm, I'm gonna say 3/8" on the pressure side and 5/16" on the return. A wrench over the line will tell you. Tube sizes are in outside diameter.86 Lincoln Town Car (Galactica).
perfect!~David~
