Also do I use the washers off the new arm (02) or the original arm (88). I wasn't sure someone had mentioned that the upper arm shaft would hve to be sanded to fit the sleeve so I didn't know what washers to use. Glad u two told me I almost cut those bastards off.
ES poly front bushings ('92-'97)
gotta use the washers and shafts from the box upper arms.......gotta cut the inner sleeves out of the 96-02 uppers if you are using them
what are you talking about? they burn out just like any other bushing
get the propane torch out.......the rubber will come out like a magic snake
they will fall off easily. The reason I mention all of that is because the new inner sleeve doesn't have teeth like the factory ones the washers can spin and loosen up the nuts. I used new locknuts and lots of lube, AND locktite to keep mine on.Builder/Owner of Badass Panther Wagons
gotta polish those washers use new jam nuts and loctite as mike posted if you dont use loctite they come loose
Hey...I'm replacing my upper control arm bushings and just wanted to confirm that the 4.3153 bushing kit will work on my 82 LTD with a police package...I read that it has threaded bushings? Thanks....-Phil
This is annoying ... I'm getting ready to order from Summit along with other stuff (and a handy discount code ), and the kit is out of stock, projected ship date 11/16. On the other hand, I may not have time to work on it before then anyway .....2012 Mazda5 Touring | Finally working on the LTD again!
