What Kind of Bushings
    Putting in springs, sway bars, shocks and most likely arm control bushings. Also the suspension arm needed for the rear police sway. Anyone tell me what bushings or connectors and stuff they suggest? I keep seeing energy absorbing? Thanks. Bob
    sigpic 1989 Lincoln Towncar, All Stock.....Today
    drill out second set of holes for the bar on the rear control arms......do you have the bolts and spacers for the rear bar?
    energy suspension 4.3150 for the front http://www.energysuspensionparts.com...sp?prod=4.3150
    energy suspension 4.3151 for the rear http://www.energysuspensionparts.com...sp?prod=4.3151
      Thanks Scott!
        You also may need to tweak the lip of the control arms to fit the rear bar in. Sort of bend them outwards so you can slide the bar behind the lip.
          Scott, I bought the correct control arm from mcninetyone also. John, thanks for the tip. Bad thing is that I'm out of cash and never expected the bushings to be that high. May have to hold off a couple weeks. That doesn't fit with my personality!
            If you think thats bad, price out a full set of stock rubber bushings. The poly is a lot cheaper.
