Need NewFront Springs....and help!
    Evening. I'm putting rear PI springs, pi shocks, sway bar and 275's under the back. Under the front will be PI shocks, PI sway and 235's. I need to get the springs ordered. I want the front to sit down over the wheels a bit. One of the suspension sticky notes says Speedway 925 will drop it about an inch. However in threads with height specs, stock looks something like 15-16". The speedway is 12". That's bait more than a inch. Anyone have any solid data to help make the right choice. Want a nice rake but not jacked up. Thanks in advance. Bob
    sigpic 1989 Lincoln Towncar, All Stock.....Today
    they are a shorter spring, but a high re rate, so when loaded the car only sits about an inch lower.
      Thanks Duce! That makes sense now. They dont collapse as far under the base load of the car.
