Wheel specs
This is a sticky topic.
    Wheel specs
    All of the Ford wheel specs:
    YEAR BOLT PATTERN LUG SIZE LUG TYPE CENTER BORE
    ASPIRE 94-on 4X100 12mmX1.5 NUT 54.06
    CONTOUR 95-on 4X108 12mmX1.5 NUT 63.9
    CROWN VICTORIA 91-on 5X114.3 1/2-RH NUT -
    ESCORT 81-90 4X108 12mmX1.5 NUT 63.6
    ESCORT LX, WAGON 91-94 4X100 12mmX1.5 NUT 54.06
    ESCORT GT 91-96 4X100 12mmX1.5 NUT 54.06
    ESCORT LX 92-97 4X100 12mmX1.5 NUT 54.06
    EXP 81-85 4X108 12mmX1.5 NUT 63.9
    FESTIVA 87-93 4X114.3 12mmX1.5 NUT -
    FOCUS 2000-on 4X108 12mmX1.5 NUT 63.9
    FULL SIZE (GALAXIE,CUSTOM,ETC.) 57-64 5X114.3 12mmX1.5 NUT -
    FULL SIZE (CUSTOM,GALAXIE,T-BIRD,ETC.) 65-72 5X114.3 1/2-RH NUT -
    FULL SIZE (CUSTOM,GALAXIE,T-BIRD) 73-78 5X127 1/2-RH NUT -
    FULL SIZE (CROWN VICTORIA,CUSTOM,GALAXIE,LTD) 79-96 5X114.3 1/2-RH NUT -
    GRANADA,LTD II,FAIRMONT,T-BIRD 78-88 4X108 1/2-RH NUT -
    MID-SIZE (FAIRLANE,FALCON, MAVERICK,MUSTANG,ETC.) 64-74 4X114.3 1/2-RH NUT -
    MID-SIZE (FAIRLANE,FALCON, MAVERICK,MUSTANG,ETC.) 64-73 5X114.3 1/2-RH NUT -
    MUSTANG 79-93 4X108 1/2-RH NUT -
    MUSTANG 94-on 5X114.3 1/2-RH NUT -
    MUSTANG GT 94-on 5X114.3 1/2-RH NUT 70.3
    MUSTANG GT (OPT.), COBRA 97-on 5X114.3 1/2-RH NUT 70.3
    MUSTANG 5.0GT 85-91 4X108 1/2-RH NUT -
    MUSTANG 5.0GT 91-93 4X108 1/2-RH NUT -
    PROBE 88-92 5X114.3 12mmX1.5 NUT 59.61
    PROBE 93-96 5X114.3 12mmX1.5 NUT 67.2
    PROBE GT 88-97 5X114.3 12mmX1.5 NUT 59.61
    T-BIRD 85-88 4X108 1/2-RH NUT -
    T-BIRD 89-97 5X108 12mmX1.5 NUT 63.9
    T-BIRD SC 89-97 5X108 12mmX1.5 NUT 63.9
    T-BIRD 02-on 5X108 12mmX1.5 NUT 63.9
    TAURUS 86-96 5X108 12mmX1.5 NUT 63.9
    TAURUS 86-on 5X108 12mmX1.5 NUT 63.9
    TAURUS SHO 97 5X108 12mmX1.5 NUT 63.9
    TEMPO 83-85 4X108 12mmx1.5 NUT 63.9
    TEMPO 85-94 4X108 12mmX1.5 NUT 63.9
    TEMPO 92-94 4X108 12mmX1.5 NUT 63.9
    ZX2 97- 4X100 12mmX1.5 NUT 54.06
    AEROSTAR 85-97 5X114.3 1/2-RH NUT -
    BRONCO 66-on 5X139.7 1/2-RH NUT -
    BRONCO II 7 82-90 5X114.3 1/2-RH NUT -
    COURIER PICKUP 77-84 6X139.7 12mmX1.5 NUT -
    ESCAPE 01-on 5X114.3 12mmX1.5 NUT -
    EXCURSION 00-on 8X170 14mmX2.0 NUT -
    EXPEDITION 97-00 5X135 12X1.75 NUT 87
    EXPEDITION 2-Jan 5X135 14mmX2.0 NUT 87
    EXPEDITION 02-on 6x135 14mmX2.0 NUT 87
    EXPLORER, EXPLORER SPORT TRAC 7 90-on 5X114.3 1/2-RH NUT -
    F1/2 TON F-100,150 TRUCK 54-95 5X139.7 1/2-RH NUT -
    F150 TRUCK 96-00 5X135 12X1.75MM NUT 87
    F150 TRUCK 01-on 5X135 14mmX2.0 NUT 87
    RANCHERO 65-84 5X114.3 1/2-RH NUT -
    RANGER 2WD 81-on 5X114.3 1/2-RH NUT -
    RANGER 4WD 7 83-on 5X114.3 1/2-RH NUT -
    WINDSTAR 94-on 5X108 12mmX1.5 NUT 63.9
    1/2 TON E-100,150 VAN 68-84 5X114.3 1/2-RH NUT -
    1/2 TON E-100,150 VAN 70-96 5X139.7 1/2-RH NUT -
    1/2 TON F-100 (4X2) POWER BRAKES 80-85 5X114.3 1/2-RH NUT -
    What about backspacing?
    Good stuff though!
      good enough that its stickied
      Save a seal, club a liberal.
        Tire Fitment guide
        Tires
        Updated: Both links broked...
        2000 Grand Marquis LS
        Mercury Owners Group member
          So according to this 93 Ranger wheels should fit an 85Colony Park.
          Is the back spacing different?
            it might be but unless you have a wide wheel you should not have clearance problems
                Tire size conversion calculator
                2007 F-150 Supercab XLT 4x4
                1997 Jeep Cherokee
                    Is that a backspace to offset conversion?
                      Backspacing
                      I am looking to get a matching set of these from Summit. What is the backspacing I should order?
                      3.75, 4.0 or 3.625?
                      I will probably got 235/60/15.
                      Thanks.
                          Thanks.
                          There was a set of 4 on eBay, but the shipping was gonna be to high.
                            To calculate backspacing and offset you use these formulas:
                            (rim width) / 2 + 0.5" + (offset /25.4) = backspacing
                            [ (backspacing) - 0.5" - (rim width) / 2 ] * 25.4 = offset
                            Examples,
                            A 16" X 8" wheels with 24mm of offset.
                            (8"/2) + 0.5" + (24mm/25.4) = 5.44" of backspacing.
                            A 16" X 8" wheel with 4.5" of backspacing.
                            [ 4.5" - 0.5" - (8/2) ] * 25.4 = 0mm of offset.
                            Take note the 0.5". The 0.5" is there to take into account the thickness of the bead lip of the wheel, since whell width is from inside to inside of the bead. The factory wheels for 79-02 Panthers are 0mm offset. Knowing this to find out what BS you need, simply divide the desired rim width by two (2) and add the 0.5". That will give you the backspacing that is best for our cars for said rim width.
                              Broked link above
                              Tire sizes.
