I was just thinking on something.
I had 3.08 gears, and sometimes I had a problem. My transmission would shift too soon under light acceleration, and I'd find myself doing idling level kind of rpms while I was actually trying to get onto the freeway. Then, you can't accelerate at all. So I'd have to give it more gas and kick down a gear.
My engine starts to get rough at 500, 600 rpm, and would stall at 400rpm (I found that out, after my electric fan conversion, would demand tons of amperage from the alternator without warning, and the sudden load would stall the engine from a healthy 700rpm idle, to 400rpms or fatally below that).
I just went to 3.55 gears, and while not perfect, it IS better. Noticeably better. I don't have to kick down nearly as often.
A mildly higher stall/ torque multiplying converter should finish the job, for a smooth daily driver.
I made things worse with an HO swap, and with heads that favor higher rpms. I know the stock lopo heads are supposed to be boat anchors, but I think they really do produce more very low end torque.
So what is it like to drive in one of the sedans that came with 2.73s?
I mean, can you almost stall the engine after an upshift? I know that the shifts are governed by output shaft rpm, so that if you have two cars identical in every way, including tv cable adjustment, just with different rear end ratios, that the 2.73 will at least shift at much later speeds (in mph), but at the same speeds according to the tach, so it won't force engine rpms to stallingly low rpms I guess... but that much load on an engine, is it even better for fuel economy?
