Originally posted by zoomie
View Post
driveshaft upgrades?
Originally posted by Southern_Pride View PostThe 180 out thing only applies to 2 piece driveshafts. Not ours.
Jay03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostAs I said, I have had hands on experience in this over many years. Rotating a removed shaft 180 degrees can and certainly has eliminated noticeable vibrations.
Jay
You are asking the same question I have asked myself before. I do not have the answer. Wish I did.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I am not saying every shaft will give you problems. I recently installed an aluminum shaft from mcninteyone and I have zero vibrations. So was I lucky in putting it in right or was it so welll balanced it did not matter? I really don't know.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
When my tranny was replaced a couple of years ago, they did not mark the shaft orientation. I had a vibration. I rotated the shaft and the vibration was gone. I have done other cars of other manufactures over the years and learned the hard way, sometimes it makes a difference.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
That makes sense.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
for the steel ones... sometimes the spider gear/u-joint at the rear can have a 180-out bit of play. Mechanic buddy of mine suggested I do the 180 trick with my Mark and see if that changes the vibes any. I still haven't done it yet though. I've been slackin.
