So! I've resolved to rebuild my rear end. I want 3.73 trac-lok/ posi/ limited slip rear gears, possibly 3.55. Not 4.10; too extreme!
Right now I have a 3.08 open rear end.
First question: 28 spline or 31 spline? Would an explorer or mustang rear axle work, to donate all the parts (and then I'd get a rebuild kit for the clutches)? It seemed that units were either 28 spline, or 31, and I don't know what I need-- before I run off and buy a mustang axle.
I assume I'd want c-clip eliminators (coworker advised)?
If I went ahead and replaced wheel bearings, too, are those straightforward? ...are they press on, such that I'd have trouble doing them myself?
for 3.55 and for 3.73, how many teeth do I want the speed wheel in the trans housing to have, so my odometer is correct?
And to be sure, I would need that center assembly --the limited slip differential itself-- and 3.73:1 ring and pinion gears? Or with the posi differential, it's just one whole unit and the ring gear is built in?
thanks!
-Bernard
thanks!
-Bernard
