Axle code?
    Axle code?
    I was looking at the door sticker on my 87 Box Wagon and the code was a "5". Any idea what that is?
    sigpic87 LTD Wagon
    5 should be 3.27:1
      Limited slip???
      no wonder it's better off the line than my 92 MGM with 2.73's
      sigpic87 LTD Wagon
        number would indicate open diff iirc. and 3.27s are odd ball but, good never the less. 2.73 and 3.08s are more common, yet dog meat lol. 3.73s are ideal.
          First thread in this forum, second post.
          Thanks for checking the FAQ.
            My apologies... When it says "Suspension/Brakes FAQ." I'm not thinking axle codes....
            sigpic87 LTD Wagon
              I always had trouble finding those, so a few years back I put them in my sig.
              3.27 isn't a bad ratio. Not much difference than the much coveted "K" code (3.55 limited slip).
              At least not much you can feel. The Ford employee who maed the final decision to put 2.73s
              on a panther, really ought to be taken out to the woodshed though.
              Axle codes
              Open/Lock/Ratio #
              G / H / 2.26
              B / C / 2.47
              8 / M / 2.73
              7 / - / 3.07
              Y / Z / 3.08
              4 / D / 3.42
              F / R / 3.45
              5 / E / 3.27
              6 / W / 3.73
              2 / K / 3.55
              A / - / 3.63
              J / - / 3.85
                All levity aside, don't make that mistake again. Mrltd will destroy you. I don't have enough fingers and toes to count the amount of times I had to beg for my digital life.
                  yeah... I tend to count axles as drive train myself.
                    In your sig it lists a "W" code for a 3.73 limited slip rear, that's not a Panther rear is it? That must be an F-series rear i'm guessing. If so are the Ring and Pinion sizes the same so you could swap on into a Panther axle assembly?
                      as long as it's an 8.8 rear axle... the gears/carriers are bolt-ons. you can swap around. Always keep the ring/pinion set together... no mixing and matching those - even with same ratio gears as the tooth angle may be just a bit different between sets.
                        If I can't locate a K code limo axle, I can get a Trac-Loc carrier and 3.73 ring & pinion kit and have the stock axle rebuilt. That plus an Explorer motor should move this boat pretty damn well.
                          3.73 better than K code lol
                            THIS! I'd like to do that to the grand marquis... but... DD duty it has.
                              It may never happen, I spotted a grown in Grand National at work the other day......
