Looks good.
Can you pop under there and measure from the inner frame rail straight down to the top of the axle tube? I'm trying to compare how the moog wagon coils measure up to proper wagon coils.
Are those regular wagon coils or cargo coils? I may want some stiffer springs for my heavy Lincoln but I don't want it raised up too much. It has a slight rake now but that could be due to worn front springs.
GM_Guy
Looks good.
Alex.
i will tomorrow when i get off work
Southern_Pride
Now you need bigger tires.
i agree...lol too bad it wouldn't be too practical for winter
88Vic
these are coils from a ford country squire wagon im not sure if i know the difference between cargo/ wagon coils
And aftermarket. If the spring looked evenly coiled top to bottom its a single rate spring. Variable rate has coils spaced close together at one end, and farther apart going to the other end.
Alex.
actually the springs i got were variable spring rate then, and im gonna go measure that thing in a minute
