I rebuilt my entire front end a year ago, except for control arm bushings because this car is my daily and the last time I did the bushings 10 years ago on my old TC it took FOREVER to get the bushings in.
I have regretted not doing the bushings with each and every clunk over each and every bump ever since.
THEREFORE, I'm going to do them, and duplicate all that labor. Yay.
This time, I want to go to Pull-A-Part and harvest 4 good arms, rebuild anything that isn't pristine on them including bushings obviously, and swap them in to minimize downtime when I actually do the job. In the case of the upper arms, I want to be able to have my newly-renewed arms inculuding the shafts sitting there ready to bolt up.
Question 1: If I understand it correctly, I can use arms off any TC/CV/GM thru '97, even if the upper arms are the tubular-looking type as opposed to my stamped type. Do I have that right?
Question 2: If I do use later arms, is there a year or model that is preferable, such as a cop car due to being stronger, or the models where the bushings are all the same or something?
(I am not doing a brake upgrade because I like my cast lacy spokes.)
It should go without saying that because I am not doing the brake upgrade, I will be re-using my old spindles.
I appreciate any thoughts.
