Just for the heck of it, check to see if the hood stops are adjusted properly. We have run into a lot of front end squeaks being caused by the hood bouncing.
Chriping sound from R. F. tire area over bumps.
Cool I will check into everything. I actually looked up this problem and a lot of people said to check just what you mentioned John.~David~
Please post what you find. I had an 82 LTC that made a squeak/chatter sound and never bothered looking in to it. The car was rusting away and died before I needed to fix it.
I have noticed it on my 89 LTC and plan to use it as a casket when I die. Thought it was a loose center cap on the drivers front but fixed that and didn't change. Had the caliper hang up on that one too so has a new caliper pads and pins the sound is still there. Clattering chirp is the best description I can think of over bumps. Sort of embarrassing like a tin can clanging underneath.sigpic
13 F-150 XLT 6.2 l
Is your bumper tight?1989 Grand Marquis LS
That's a good point, my front clip squeeks. You can recreate it just pulling up or down on the bumber.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Originally posted by 86VickyLX View PostA thought just came to mind. Phil's LTD-S had a rattling chirping noise when he would go over bumps. It turned out to be worn out caliper slide pins... That may be your issue?Originally posted by 87gtVIC View PostCool I will check into everything. I actually looked up this problem and a lot of people said to check just what you mentioned John.
Originally posted by 1990LTD View PostCan you replicate it by pushing down on the bumper and releasing?
How is the outer tie rod end?
I would pull the caliper and lubricate the pins etc anyway
I'm just funnin'!
I hope you get this figured out Dave. Little noises drive me fucking NUTS man.sigpic
My mechanic (dad) took a test drive with me last week some time. It seems to be more of a metal to metal squeak deal, rather than tire chirpage....after-all I cannot drive and stick my head out of the window to listen to the offending area. We jacked the car up, tightened the chassis braces, pried on a couple components and determined that the lower body mounts are shot. Put a jack stand by the frame where the ac usually rusts it out and then jacked up the body of the car and there was a lot of play. Dad told me that was the big thumping sound I would hear on other occasions when the suspension just drops out from a really big hole. He figures that all sounds should go away with new bushings. I guess new body bushings should improve how the car handles as well. Now to find replacement bushings.
And the bumper is tight. I was bench pressing the front end with it while looking for suspect places.~David~
body bushings is probably the issue with my 93 and some of it's jitters too. but they're still good enough to not sound off like that. The 88 on the other hand... it's getting nice and squeaky on the driver side. That may have more to do with the new poly bushings though... I'm planning to grease them some more when I get under that car next.
