Finally got around to putting the PI swaybar on the rear. I had already checked that I did indeed have the holes drilled in the lower control arm. I lined up the holes as best as I could and got this:
I know I've got it too far back here, but the alignment issue is vertical
Am I making some weird mistake here? Is there any way to drill the holes out so that this work? I thought about trimming or bending the lip on the control arms, but I'm not sure if I'd weaken them too much.
Anyone run into this? thoughts? I fought with it for about 10 minutes and it's just not possible to thread the bolts in there, and I was using the stock hardware. The bar is jammed right up against the lip of the control arms.
