If you want any info added, PM me or Duece and we will add it.
Control Arm Shaft Nut Size is 5/8"-18
Sway bar sizes:
1 3/16" (wagon)
1 1/8" (PI/Towing package)
Rear bar Sizes:
(civilain)
1" (PI)
Front Springs:
Base: 374lb/in
Wagon: 443lb/in
HPP: 540 lb/in
P71: 700 lb/in
Rear Springs
Base rear coils: 107 lb/in
Wagon rear coils: 182lb/in
P71 rear coils 160 lb/in
HPP bags ~110 lb/in nominal
(More spring info in later post)
Shocks:
All are interchangable up to 02. Many, many cars use the same shocks.
Street stock shocks are an affordable alternative for the $80+ Edelbrocks and Bilstiens and are available in various valving.
Fox Mustang shocks also work in the rear.
Wheels
Stock wheels are 5x4.5 bolt spacing. Backspacing is 4.25"
Wheels are interchangable for the most part up to 02, though because of the brakes the centercaps won't fit (depending on the style of cap.)
Explorer and ranger wheels fit, some Jeep and Chrysler wheels to.
1994-2003 Mustang wheels fit 79-91 panthers with 1-1.25" spacers. Modifications to the centercaps to fit with the 1" spacers and stock brakes. With the big brake conversion done, 1" spacers are fine.
2003+ panther wheels and 2005+ Mustang Wheels can be used, however they require a 1.5" spacer/adapater that costs about 150 bucks for a set.
The following information is from my 1989 Town Car/Crown Victoria/Grand Marquis Car Shop Manual:
Wheel Sizes/Offsets: (From '89 Shop manual)
(Thanks to 89GrandMarquis)
Town Car
Steel 15x6 Offset=0.45" Tire=P215 70R15
Alum (cast lacy spoke) 15x6 Offset=0.35" Tire=P215 70R15
Alum (cast turbine spoke) 15x6 Offset=0.45" Tire=P215 70R15
Alum (cast wire spoke) 15x6 Offset=0.35" Tire=P215 70R15
Crown Vic/Grand Marquis
Steel police 15x6.5 Offset=0.35" Tire=P225 70R15
Alum (cast) 15x6.5 Offset=0.45" Tire=P215 70R15
Steel 15x6.5 Offset=0.45" Tire=P215 70R15
Alginment Specifications (From '89 Shop manual)
(d equals degrees)
Item Nominal Minimum Maximum
Caster +3.5d +2.5d +4.5d
Camber -1/2d -3/4d +1/4d
Toe +0.063" -0.063" +0.188"
(+1/16") (-1/16") (+3/16")
+0.125d -0.125d +0.375d
Sway bar sizes:
1 3/16" (wagon)
Rear bar Sizes:
(civilain)
1" (PI)
Front Springs:
Base: 374lb/in
Wagon: 443lb/in
HPP: 540 lb/in
P71: 700 lb/in
Rear Springs
Shocks:
Originally Posted by Southern_Pride
Fox body rear shocks also fit. I just put a set of the koni red rear shocks on the back of my car. Just a heads up.
Wheels
Town Car
(d equals degrees)
