I was wondering what component is responsible for the play in the steering wheel (I can move the wheel either direction one or two inch's without affecting the steering at all. In other words its not sensitive enough). I'm convinced its either the ball joints or tie rods. I have fairly new motorcraft ball joints, but could it be that they are bad quality?
My other question is how much oil are you supposed to inject into the ball joints/tie rod ends exactly? I got Moog tie rod ends and I'm also wondering if they need oil injected into them at all.
I'm planning to replace my lower control arm bushings, shocks and inner/outer tie rod ends tomorrow. I've read up as best as I can on other threads. Any advice and fore warnings are appreciated!
~Stealthlead
~Stealthlead
