Since I cut my teeth on the C-20 front end rebuild, I'm gonna tackle the CV front end next. So far I sized the bolts and nuts to the different components. Both the UCA and LCA bolts seem to be 21mm on my mom's '86 CV. The upper balljoint castle nut is 7/8" (it fits better than the 21mm) and the lower balljoint is 24mm. I have yet to size the inner and outer tie rod nuts.
My plan is to grab the LCAs, spindles, and UCAs off of the '90 MGM that I began stripping last year (if it's still there). At first I was thinking that I may not need to bring power tools, but upon further thought I may have to. I'm thinking that I might cut the springs off of the donor vehicle before I separate both control arms from the spindle. Is that a good idea or bad idea; or not the proper thing to do in a JY? Also, the UCA bolts; are they held in place by a nut on the other side? Only reason I ask is because I can't see the other end of the UCA bolts because they poke into the frame. I want to have everything I need when I go to the JY. I think that's all for now; I'll post more ??? if I can think again. Thanks guys
