I'm tired of changing these damn things. Even the moog ones only last about a month before they get some slop in them. Lifetime warranty is nice but it should last more than 5k miles.
Who makes a GOOD idler arm?
1989 Grand Marquis LS
flat black, 650 double pumper, random cam, hei, stealth intake, Police front springs, Wagon rear, Police rear bar, wagon front ,exploder wheels, 205/60-15 fronts 275/60-15 rears, 1 5/8" headers, 2.5" offroad x pipe, Eclipse front bucket seats, Custom floor shifter, 4.10 gears, aluminum driveshaft and daily driven. 16.77@83mphTags: None
I was thinking about replacing just the bushing on my OE one. Since you've already changed the arm out... that option is gone. Personally, I've never had any issues with the store brand stuff... so if Moog is crapping out on you... there may be some binding going on in the tie rods to be putting that much stress on the idler arm.
Most of it is my big ass tires. But still someone should make a better one.1989 Grand Marquis LS
from looking at my car (and remembering what was on the 85 pontiac b-body I had) I'd say check out a Humvee idler arm. If you can find one to compare with that is. Otherwise check out truck idler arms and see if you can find one with the same bolt pattern and arm length/end angle. It looks like the GM and Ford arms are compatible, just mounted on opposite sides of the center link.
i got a pep boys cheapie on my towny.......installed it in 2002......still tight.......back then they were like 9 bucks
Inspect the centerlink. Make sure that it is not bent or damaged. If the center link is putting the idler arm at a weird angle, it will wear out fairly quickly. Has the car been in any accidents, have you run over anything in the front? All stuff to look out for. How long does an idler arm last you?
Would getting measurements on the replacement bushing, and then sourcing a poly part be an option?86 Lincoln Town Car (Galactica).
I did hit a rut hard enough to bend a tie rod end a bit. A poly bushing may be a solution. Not sure. As far as lasting, they get some play almost instantly but takes a few months before it gets bad enough to change. 10-15k miles maybe?1989 Grand Marquis LS
Try Spicer Chassis group. They are now a division of Dana/Raybestos under the parent, Affinia, Inc. I started using them on my GM B-body, as they also are hard on idler arms and i grew tired of the Moog Problem Solver (their high end brand) crapping out. Energy Suspensions may also make something for the Boxes. They are pure polyurethane bushings, but, be prepared for squeaking with them. Polyurethane does not 'lubricate' as easily as rubber.95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
96 Buick Roadmaster Limited Wagon, mostly stock
77 Ford F150, 400M auto, longbed
98 Suburban LS 5.7L Vortec, stock
90 Grand Marquis, stock
Originally posted by gadget73 View PostWould getting measurements on the replacement bushing, and then sourcing a poly part be an option?2012 Mazda5 Touring | Finally working on the LTD again!
