I dropped my steering wheel to remove the dash.
The wheels are almost straight, pointed a couple degrees to the left.
I noticed before I bolted it back up into place again, that it appears to be upside down!
I've taken steering and suspension class, we went over some of these things.
We did a rack&pinion R&R so we had to quite deliberately unbolt the steering column from the pinion gear, obviously lets the wheel flop around.
I know that when you do an alignment, you can end up changing the steering wheel orientation, though I'm not sure how. My team stripped the pressure line to our steering rack, so the day everyone else was doing alignments, we did a steering rack R&R for the 3rd or 4th time (don't ask)
If you have a '96 corolla with a steering rack problem, I'm your man, hahaha.
Anyway, what I'm getting at here is that I don't think/ don't know of one thing that would result in an upside down steering wheel just because I dropped the column from the dash with those 4 bolts.
But you guys know these cars better than I do; I did my first oil change 10mo ago and am still quite the greenhorn. What'd I do and how do I fix it? The wheel does not rotate freely, so if it did get unhinged at some point, it surely isn't now.
Thanks!!
-Bernard
Thanks!!
-Bernard
