Sorry to pester you all with more questions, but there's a whole lot I don't know that I'd like to.
What needs to be done to separate the axle from frame besides shocks? My limited knowledge tells me there are control arms and then the bolts above the pumpkin (#?) through the bushings.
What needs to be replaced besides the rotors/calipers/pads, and the internals of the axle? I'm talking bushings etc and parking brake bits...I'd like a functioning parking brake but if it's $$$ to replace everything, fuck it. As long as it works once to pass inspection
If there's stuff I can get away without replacing, GREAT.
Also - I have a sway bar for my 1990 that I wanted to install. Can I still use it with the 95 rear axle since it only bolts to the control arms, or are they located further outboard?
