Leaking gas tank
    Leaking gas tank
    While replacing the shocks, I found a small leak in the gas tank. It looks like it is rusted (lot of rust under the car) on the lower seam. It will drip about one drop every few minutes or so. The question is can it be fixed or what year will fit to replace it.
    if i were to do a patch, it would be a short temp repair. as for replacements, i belive tans from 1986-91 will work. question is, do you have a seperate fuel pump and fuel gauge sender? i have never seen the tanks with 2 holes but, im told they exist.
      As far as I know the pump and sending unit are in there own holes. The sending unit is on the side and I guess the pump is on top. I don't think it can be fixed by a patch.
        then a new tank it is!. when you get the new tank, coat the seems with POR 15 then paint the whole outside.
          just buy a new tank,in pa fuel tank repairs are a nono for inspection...... rock auto has them pretty cheap, see if your local parts places will match rock auto price, the autozone i deal with will match rock auto price whenever they can cause i spend a decent amount of money there
            Sedan or wagon? Carb or SEFI?
              Thanks, Sedan, SEFI. Auto Zone and Adv. Auto both have them. I will have to order it from either one of them.
                Sounds good, especially with all the discounts Advance is throwing around these days.
                Now if someone would just need a tank for a wagon already so I can get one of my two spares out of the garage ....
                  I need one for my wagon, however... I need a custom one.
                    Well, you're no help!
                      I think a gas tank is the last place you want to rig something up.
                      Town Coupe [X]
                      Mark VI [ ]
                      Grand Marquis Coupe [ ]
                      Crown Victoria Coupe
