Stock "boxed" control arms with new bushings are probably better for a street car?
Rear control arm options for the boxes
Originally posted by N AStock "boxed" control arms with new bushings are probably better for a street car?http://secondhandracing.com/Home.aspx
Also, as for the streetability, the panther is a body on frame, so it won't be as bad as the t-bird. I'd still stick with boxed and poly's for the street in most apps. I'm prolly going to go with poly on the frame side and hiem on the axle.Builder/Owner of Badass Panther Wagons
Originally posted by mrltdAlso, as for the streetability, the panther is a body on frame, so it won't be as bad as the t-bird. I'd still stick with boxed and poly's for the street in most apps. I'm prolly going to go with poly on the frame side and hiem on the axle.http://secondhandracing.com/Home.aspx
