Originally posted by GoodSamaritan
View Post
I know I could make a pedal assembly and have it look and function well. It is absolutely critical that it works perfectly, but I am stickler for visual details. When I look into the foot box I want to see arms that look like they came there, that are somewhat lined up (the clutch pedal in my truck always sits higher than the brake pedal). I just thought starting with a universal piece and modifying it would be easier. I have to study the firewall and floor pans more in order to know if its even possible.
Also, I have no intentions of using a T5. I like the low range first of the TKO 500. The TKO 600 is obviously a possibility, but I have heard of folks complaining about shifting the TKOs. The T56 would be expensive, but pretty much the ultimate.
McLeod was supposed to be releasing a transmission of their own (the M880?), but it hasn't come to the market yet.
I'd prefer to use a hydraulic clutch.
Like I said, this is just research. But with what I am planning on doing here down the road, the T5 will be inadequate. As I discussed in my reader's ride thread, my engine build options were a windsor stroker, or a 500 inch Cadillac (or an LS, in which a T56 would be the trans).
And if you're saying to yourself that it isn't possible to put a manual transmission behind a big Cadillac, you'd be wrong. There are a few folks that make what I need.
I am still on the fence about a stick shift all together, because I will be doing quite a bit of racing with this car. If I did the swap before an engine swap, a windsor stroker would be the simplest engine build. But with a new flywheel, bellhousing and clutch I could probably make the 500 work.
