4wd does not stop better than 2wd. It just goes better.
ABS in a Box
What about throwing your 4x4 into Reverse and hammering the gas? Oh, wait ... unless conditions are absolutely perfect, that'd just send you into the ditch even faster ..... :3gears:2012 Mazda5 Touring | Finally working on the LTD again!
I don't know about anyone else, but I don't do much panic braking in the snow. Evasive driving in the snow is much easier with a 4WD. Cutting the wheel and giving it some gas will often pull you through rather than causing the ass end to come around, requiring you to saw on it to get it where you need to go with any sort of control.
I also don't throw my vehicles into reverse; that requires full lock up before shifting into reverse, with a manual transmission. Its also a pretty absurd idea.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
wouldn't 4 wheel drive and a manual give an engine braking advantage?
I think ABS is a wash in the snow. yeah it won't dig in, but you can steer. It seems like about 50/50 to me when I've needed steering or super-fast stopping more to not hit the guy. plus, ABS on ice is far superior.
I always take advantage of engine braking, with my truck. I usually rev match my down shifts, especially when it is snowy, or wet out. I despise when folks just downshift something without blipping the gas to bring the revs up a little. In the snow, that unintentional jerk could result in loss of control.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by gadget73 View Postsometimes you have to get places, no matter what the weather is doing. The world does not stop just because it snowed. Unless of course you live somewhere south of DC.Builder/Owner of Badass Panther Wagons
Maybe earlier ABS systems suck, but on my 97 MGM worked just fine, with good front tires and studs on teh back. I don't take snow days, I'll drive in anything. Rather have ABS than not. Although once coming to an intersection with construction, I hit gravel, and it did send me out past the light into the other street. Not sure if it would've happened without ABS.
Even the primitive limited slip has a use. You know how, coming to a stop sign on a slight uphill grade in the snow, it can be difficult to get going? It did help.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Originally posted by Piece-it pete View PostNot sure if it would've happened without ABS.
Pete
The traction assist is good for non limited slip rear, since it applies brakes to the free spinning wheel. Which in turn makes the opposite wheel the freer spinning wheel, so it kinda makes an open rear a limited slip.
Originally posted by P72Ford View PostI also don't throw my vehicles into reverse; that requires full lock up before shifting into reverse, with a manual transmission. Its also a pretty absurd idea.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 86VickyLX View PostYou would've stopped instead of going through the intersection.
I'm not sure about the gravel stop, because it was gravel where there usually isn't, on pavement, and I wasn't prepared (shame on me). Got lucky no traffic.
Originally posted by Piece-it pete View PostAs so, thanks for the 'traction assist' clarification. I would've liked a off switch for it because it interfered with snow donuts.
Pete
Originally posted by 86VickyLX View PostAnd also, note that wheels will slip before the trak lok grabs the other wheel. That's why it's called a limited slip, not a locker...
A locker physically locks the axles together. There are no clutches or cones to "slip". When you go around a corner with a Detroit Locker, the outside wheel unlocks the diff when it spins faster. They are far less forgiving on corners with low traction.Last edited by Mercracer; 06-06-2011, 03:54 PM.
open rears apply power to the one with the least traction. A clutch-based limited slip like we have applies power roughly equally under optimal conditions, but as the clutches and stuff wear out, its less and less even. I think under new carrier conditions its something like a 60/40 split, 60% going to the side with less traction. As it wears, that number gets worse and worse until its no better than an open rear. The clutches do slip in a turn, but its not a slip then grab situation under low traction. There are other types of carrier that will actually transfer the bulk of the power to the wheel with the most traction, but then you're into stuff like a TruTrac or one of the others that uses a torsion bar arrangement instead of just the friction discs.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postopen rears apply power to the one with the least traction. A clutch-based limited slip like we have applies power roughly equally under optimal conditions, but as the clutches and stuff wear out, its less and less even. I think under new carrier conditions its something like a 60/40 split, 60% going to the side with less traction. As it wears, that number gets worse and worse until its no better than an open rear. The clutches do slip in a turn, but its not a slip then grab situation under low traction. There are other types of carrier that will actually transfer the bulk of the power to the wheel with the most traction, but then you're into stuff like a TruTrac or one of the others that uses a torsion bar arrangement instead of just the friction discs.
