So, when you install this you are going to have the traction assist as well? Does it use the same sensors as ABS?
ABS in a Box
Past Panthers
You should paint that toolbox for your dad. Rustoleum gloss white brush paint would do nicely.
ABS and traction assist is basically the same system, but the traction control will engage without the pedal applied and it only messes with the rear brakes. Same sensors and all that. It just sees one wheel spinning faster than the other, and applies some brake pressure to the faster side. It does require a 4 channel abs system and a different brain but the hardware and electrics are the same.86 Lincoln Town Car (Galactica).
Originally posted by P72Ford View PostThats a fairly substantial harness.
I don't think my truck (which is an '04) has ABS at all (front or rear). I can easily lock the brakes up in the snow. I've never locked up the brakes on the asphalt in that thing. I think you'd go through the windshield first.
My red car and my blue car were easy to lock the brakes up on, even on the dry asphalt.
Pics of a sorta test fit and the carnage.
In the pic where I point to the connectors, those are for the ABS pump/hydraulic control unit. I will need to extend the wiring so it will reach where it has to go.
For those of you who don't know, the HCU/Pump is bolted to the frame, right above the steering box. The inner fender goes around that, in the later years, (aeros and whales) that is slightly different. I will need to slightly modify the drivers side inner fender to allow the mounting of the HCU. I will most likely cut out part of the panel so it fits properly.
Traction assist is just using a couple of extra valves to apply the rear brakes when it sees slipping from only the rear end only. Such as starting off too fast in wet conditions. Needless to say, I will wire in a toggle switch to turn it off.
Originally posted by gadget73 View PostYou should paint that toolbox for your dad. Rustoleum gloss white brush paint would do nicely.
Originally posted by 1987cp View PostYay for primitive traction control! Is this the type that's useless if you have Trak-Lok?
I think as long as you're not a total hooligan the trac-lock doesn't cause enough slippage to trigger the trac-control/abs.
Most (all?) ford pickups and SUVs come with traction control now, and many are also equipped with trac-lock, on close cousins of our 8.8 axles.
Originally posted by 1987cp View PostLOL ... with more than 150hp, you don't always have to act like a hooligan to lose traction.
Originally posted by johnunit View PostI think as long as you're not a total hooligan the trac-lock doesn't cause enough slippage to trigger the trac-control/abs.
And also, note that wheels will slip before the trak lok grabs the other wheel. That's why it's called a limited slip, not a locker.
Regardless, I'll see how the two play together. I will have a toggle switch wired in for Traction control if they don't get along with each other...Last edited by 86VickyLX; 05-26-2011, 12:25 AM.
Here's an update, no pics yet. I got around to extending the wires that needed extending. I also rewrapped the harness in conduit and electrical tape. Looks stock. 2nd mock fit tomorrow. If I like it, I'll install the harness so I can have the fusebox.
Originally posted by PICKUP6772 View PostHHMMMMMMMM, why do I have an 89 Grand Marquis???? Oh yes!!! No fucking abs to needlessly send me through intersections i need to stop at!!!!!!! ABS has gotten me into more trouble than I can count. And if I want air bags, I'll just take the wife, and daughter with me!!!!1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
if it's single modulated ABS I totally agree with the unable to stop (had that happen with a chebby... bumped a car just cause one wheel locked and the ABS kicked on for all 4 wheels) ... but if the ABS works on each wheel independently... then that would be good stuff.
