A few weeks ago I cracked the valve housing for my air shocks, and it will bleed the shocks to a low level. The car has lost the rake it once had due to the lighter front end and air shock issue. I think I like the level look and know the weight transfer advantage due to the increased softness of the rear shocks. Just curious what yall think as far as having a rake or not.
Rake or No Rake
Rake or No Rake
NA-15.78@91.21, 80hp shot-14.48@96.21 -
I like the rake my wagon cargo coils give my car. Though I do not like how it handles with them. Straight line no problem, but turning sharp and you feel the ass swinging.~David~
i say no rake..for looks AND functionality-Phil
rakesigpic
I like them level.86 Lincoln Town Car (Galactica).
I think front-down vs ass-up rake is ok... ass-up rake was just a phase for me.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
for heaven sake, do not have any rake in the rear. your car must be slammed to the ground...
I suggest a slight rake, just so the rear doesn't sag too much when you put something heavy in the trunk.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Originally posted by GoodSamaritan View PostI suggest a slight rake, just so the rear doesn't sag too much when you put something heavy in the trunk.-Phil
Depends.
On a car that is lower than stock, I like it level, or with a slight drop in the front.
With a lifted truck, I like the rear slightly lower (Cali lean). A leveled truck (raising the front) isn't bad either, as it usually gives the illusion that the front is higher.
My truck is leveled via dropping the rear... but the rear is still a little higher than the front. When you lower a truck, it needs to be level, or higher in the rear).
Also, I really like the 'pitched' look of straight axle 'Gassers' of the '60s. That is a fine example of when a raised front looks good.
So, its a complicated answer from me.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by marquisman View Postfor heaven sake, do not have any rake in the rear. your car must be slammed to the ground...
I vote slight rake....
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
slight rake seems to better for handling on the launch off the line in my exp.'88' MGM wagon (mine and my sons toy)
"60" chrysler New Yorker (my project)
"78" Chevy 1 Ton P/U (yard horse)
"01" Ford Explorer (wifes DD)
"93" Chevy Suburban (my DD)
Cali lean. I like my front a end a little higher than the back. Drives better with no caster don't you know? lol1989 Grand Marquis LS
