I have a 1989 Town Car and I want to swap in an aluminum driveshaft. I've been reading some posts here but i'm still confused about it. Are there any junkyard driveshafts that are fairly simple to make work or should I just take my steel one to a shop and just have them make one?
Question regarding swap to aluminum driveshaft
if you can find a box Towncar with an aluminum shaft, you're good. I've never found a good one. They're rare enough but the few I've found were bent from forklifts86 Lincoln Town Car (Galactica).
What's the advantage of an aluminum driveshaft? Weight reduction? Or is there something else?Originally posted by gadget73There is nothing more permanent than a temporary fix.
weight reduction for sure and usually better balance (able to go faster) from what I've heard.
you'd think so but I've been told that the aluminum or metal matrix shafts are less prone to breakage than steel. I don't know if thats true, or if its just because the aluminum tubes are larger and thicker, and therefore stronger than the steel ones.86 Lincoln Town Car (Galactica).
Depending on the cross section (diameter, wall thickness) and weight of the shaft, an aluminum driveshaft has less rotational mass (less inertia), which means it takes less power to spin. Not that the driveshaft is the primary consumer of engine power in the driveline, but I suppose every little bit helps.
Theres also an obvious weight savings.
Also. Increasing the diameter of the shaft has a greater affect on strength than increasing the wall thickness. Thats why you see late model diesel pick- ups (GM) with 6" diameter aluminum driveshafts.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
If you plan to go with a 4:10 ring and pinion, they will cut down on the vibration.
In my case, my original shaft, appears to have been welded by an amateur, and was more than likely, WAY out of balance. I noticed a substantial differenceat interstate speeds when I swapped shafts.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
