another big brake swap
    got started with the big brake swap also newer booster and master and gonna run new brake lines front,back.also got to getting rid of rust on frame
    Nice... I plan to follow suit soon!
      very nice!
        Dear Panthers,
        4th of Juluy weekend, clipping long the New York State Thruway at 75 mph, around a turn and traffic ahead was stopped. I was sure glad for those big brakes.
        Donald McCaig
        1989 CP Scottified steering, suspension and big brakes, 16 in wheels, A-pillar oil & temp gauges, remote entry, backup sensor, tailgate wiper, custom console & trash, tranny & ps coolers, 3 cell radiator, electric fan, dual exhausts, battery isolator, hellas headlights,deer pusher,wads of dog hair.
          got pass side done and tommorow gonna start running brake lines.did some more rust removal and its looking better than before.im not looking foward to getting this thing aligned
            more pictures
              looks good. Finding a good alignment shop is a pain but once you do, actually getting the thing done is fairly easy. It took me 3 shops to find someone who could make it go down the road straight. Oddly enough, all they did was set it to stock specs, which is what I asked the first two shops to do.
                Nice job. This is something I really want to do. Just getting the parts is the difficult part.
                  getting parts was easy getting time and motavation is hard.got brake lines done and what do i do about the connector for the master cyl,dont want brake light to come on?and what brake fluid should i use once the brakes are bled im gonna set my steering up so i can get it to a alignment shop.when thats all done its tranny time.
                    nice werk mang!
                      Should just be able to use DOT3. I just use DOT3 "Supertech" brand. Wal-Mart's house brand. It's all the same stuff.
                      Edit: What's with the exciter ring on the rotors? Adding ABS? I would love to see that.
                        looks like he bought an ABS hub/bearing
                          Nice job So which booster and master cylinder did you use? 98-02 non abs, non traction controll, non PI? Have you put rear disks on that car?
                            i used 98 booster and master cylinder non abs, non traction controll, non PI. bought hub/bearing and it came with it and next will be a rear with disks
                              pete:
                              the abs hub bearings are cheaper......the non abs ones are alot more
