Setting up the interface between the ring and pinion gears is the difficult part. At the very least you need a dial indicator with magnetic base, a micrometer (0-1), a ft*lb torque wrench, an in*lb torque wrench, ... and a caliper never hurts, either.
A pinion depth tool would also be nice to have.
Of course, there is a member on this forum that I watched set up a set of 3.73s, by 'feel'. He knows I'm an anal bastard though, so he bought a dial indicator just to appease me. And after checking the backlash, and looking at the contact pattern between the gears, his 'feel' proved to be perfect.
And the rear has been silent since it was done, about 2 years ago.
After watching Scott (and a few other talented guys), I have successfully completed 4 gear swaps since, with no issues (2 GM 10 bolts, a 9", and a GM O type rear). I had someone ask me about putting 3.73s in a GM 10 bolt (8.5) yesterday. They're very similar to the Ford 8.8.
Its important to know how changes to the shim pack will affect the way the gears mesh. With patience and a little experience it can be done the right way.
**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser **2006 MGM,"Ultimate": 4.6/ 2.73/ Dark Tint, Magnaflows, 19s, 115K Daily Driver **2012 Harley Davidson Wide Glide (FXDWG):103/ Cobra Speedsters/ Cosmetics, 9K Poseur HD Rider **1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Truck Duties
Dang it, I just keep hoping that the answer will change to, sure, no problem, 20 minute job
Thanks for the info!
Pete
Scott bought the dial indicator do appease me...And then the diff failed. Nothing to do with the install though. Stupid junk trutrack
He told me he'd never used it prior to my car... :confused:... and we both had to figure out how to adjust it (it wasn't like the rigid base one I have, it was more of a slinky thing that you could tighten in position).
Regardless... he must have known that engineers are difficult customers...
:p
