Hey guys, the sticker on my door is unreadable, and I could not find a tag on my axle. On the build sheet under rear axle tag number is printed out 014A. It is defininetly an open axle and I am sure it is original. My service manual was no help. Does anyone know what ratio it would be?
rear axle ratio question
sigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
"In order to know virtue, we must first acquaint ourselves with vice" Marquis de SadeTags: None
If it is bone stock, no sway bar or heavy duty stuff, I would guess 2.73. I think that's what most of them have. But I have been wrong before!89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
When I went junkyard shopping for my axle I found that almost all boxes had a 3.08 unless it was set up with the towing package, then 3.55's. 3.27's were rare, as were 2.73's. I'd love to compare build sheets wid youse, but I AIN'T GOT ONE!!'84 Grand Marquis
Damn thing just keeps runnin'!
"Half the harm that is done in this world is due to people who want to feel important." T.S. Elliot
ps. It's pretty easy to calculate your rear end gear. Jack up one wheel. Slide underneath and put a piece of masking tape on the rear u-joint in such a way that you can tell when the drive shaft makes one revolution. Now, put the car in neutral (block a front tire!!!) and spin the tire off the ground by hand 5 times while counting how many times the driveshaft rotates. Almost 31 times? 3.08. Almost 33 times? 3.27. A little over 27 times? 2.73.
You don' need no stinkin' tag!!!!!'84 Grand Marquis
I've got 2.73 open in both of my panthers. Probably the "flat land" setup since I'm in Texas and both cars were originally shipped to Texas for sale as far as I can tell.
Originally posted by 1980c10 View PostWhy is your sticker unreliable?sigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
keep in mind a worn out LSD can pretend to be an open diffsigpic
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by slymer View PostI've got 2.73 open in both of my panthers. Probably the "flat land" setup since I'm in Texas and both cars were originally shipped to Texas for sale as far as I can tell."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
UPDATE duh
So I guess I need new reading glasses worse than I thought! I went back to the '86 service manual and looked through all the rear axle section and found 2 charts. First is for open diff
ID TAG Ratio
039A 2.73
422E 3.08
033A 3.08
014A 3.27
012A 2.73
014A 3.08
Cool my 014A could be either a 3.08 OR a 3.27!!!!
Locking diff
ID TAG Ratio
013A 2.73
015A 3.08
034A 3.08
201A 2.73
203F 3.08
205F 3.27
421E 3.27
423E 3.08
I can understand having more than one code for a specific ratio, but having the same code for 2 different ratios? dang engineers I am back to the drawing board.sigpic'86 GM LS sedan bone stock 113k triple dark sable, most of the bells and whistles, second owner. SOLD 9/10, will be looking for an 89 TC when the time is right
theres a metal tag with the gear ratio on one of the rear axle cover bolts......prob a 3.08 open......most common
My Vic doesnt have any excessive options and I have a 3.27 open. I am pretty sure the buyer of the car could specify what gearing they wanted.-2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
-1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
My car has the plain jane 3.08 open rear end - If I found another Panther rear end, would it be worth it to swap it out for either a) 3.08 locking diff or b) an open diff with higher gears?sigpic
Originally posted by 1990LTD View PostIf I found another Panther rear end, would it be worth it to swap it out for either a) 3.08 locking diff or b) an open diff with higher gears?-2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
28 spline
