I've got a question about some parts...
    When I bought my car it came with 4 new springs and struts. Can you help me determine how good they are?
    The springs - no idea what brand, only found markings on the fronts and the #s are as follows. If it isn't enough info then I understand, but they were bought as a set so the rears *should* be matched. only numbers found were 6016 P9046
    struts - Tokiko gas struts HE 3480 and then there was an FF1 below that.
    Thanks for any help. The guy I got the car from wanted to make a police interceptor, so I assume these are stiffer than stock.
    1985 GMC 1500
    Looks like (from research Ive done) that the struts are replacement for 80s mark 6s and 92-98 police interceptors? does this make sense? Here is the link,
    http://www.jdmhub.com/index.php?rout...duct_id=327484
    Im still not sure about the springs.
    1985 GMC 1500
      The shocks interchange from 1979-2002, so if they fit any panther, they fit your car.
      Moog 9046 spring
      http://www.amazon.com/Moog-9046-Cons.../dp/B000C57U4W
      can't find the spring rate but its probably stock replacement for your car
        Ok if they are stock spring rate then Im not going to bother replacing the ones I have, as they are fine. Plus Im holding out for some air ride.
        1985 GMC 1500
