Looking from the back, there seems to be fluid leaking from what looks like some kind of nipple or something on the top of the axle on the left side. Its not dripping or anything but it looks like its soaked up into the metal or something. I tried turning the nipple thing with the rubber top but its not a screw and just spins around...
Leaking on left side of rear axle?
Is this thing on the axle tube itself or on the very end on the backing plate for the drum brakes?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
air vent. Probably doesn't mean much, but you may want to consider having the diff oil changed when you have some extra cash. I doubt you have anything to worry about though.86 Lincoln Town Car (Galactica).
Like gadget said, it's a vent. It has to work or be open, you can blow the seals if it is plugged.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
