... anyone ever used one? I was looking at idler arms at Autozone.com and saw that for a whopping 8 bucks they offer just the bushing, versus more like $30-$50 for the whole idler arm. Only problem: I'm not coming up with any info on how to install the repair bushing, so I figured I'd ask if anyone else has done it.
Idler arm bushing repair kit
never tried it, but its probably a pain in the ass, akin to doing control arm bushings.86 Lincoln Town Car (Galactica).
Doesn't sound encouraging. I may go ahead and pull one of mine, and see if I can't get it apart with some sockets and a vise.
Will I need a pitman arm puller or somesuch to get the idler off of the centerlink?2012 Mazda5 Touring | Finally working on the LTD again!
You might need a lot more than just a puller. That thing bonds to the center link something fierce. Mine came off in peices after much persuasion from a BFairHammer.
At 30-50 bucks over the life of that part, having to take everything apart anyway, along with the time to r&r, I'd just replace it. Another thing to check, is your idler arm (that bolts to the frame) bolted to the link, or is it swaged (looks like a rivet head) over to keep it in place? If its swaged, you won't be replacing its bushings.
Alex.
dont waste your time rebuilding an idler arm....been there done that.......just buy a new one
Ahh you made it home!~David~
Just went out to harvest the good idler arm off the wagon, but was only partly successful. Which brings me to a more obvious and very n00bish question: What tool is preferred for pulling the idler arm off of the centerlink stud? I fiddled with that one a little, and concluded that it may be easier to remove the whole steering linkage and swap it over as a unit, thus providing me with relatively fresh tie rod parts as well.
Which reminds me: when removing and reinstalling a Pitman arm, is a new nut required?Last edited by 1987cp; 12-15-2009, 03:14 PM.2012 Mazda5 Touring | Finally working on the LTD again!
bang on the side of the center link where the idler arm stud goes through. It should deform it just enough to pop the stud free. A ball joint splitter will also serve if absolutely nothing else will make it let go.
No new nut required for the pitman arm. New cotter pin is a must tho.86 Lincoln Town Car (Galactica).
Cotter pin? I recall seeing just a very large nut securing the pitman arm onto the steering box. The balljoint on the other end would use a cotter pin ....
No luck so far parsing the stud advice. What I saw was a stud that appeared to be permanently part of the centerlink, and the idler arm stuck securely to the stud. :headscratch:2012 Mazda5 Touring | Finally working on the LTD again!
The end where it attaches to the center link should be a castle nut and a cotter pin if memory serves. Just a bigass nut on the box side.
ok, you're right. idler arm doesent have a stud, the center link does on that end. Been a while since I had one off.86 Lincoln Town Car (Galactica).
Check out the Moog idler arm. It's a different, improved style than what came on the cars, and it has grease fittings. My steering is more sure of itself now.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by 1987cp View PostJust went out to harvest the good idler arm off the wagon, but was only partly successful. Which brings me to a more obvious and very n00bish question: What tool is preferred for pulling the idler arm off of the centerlink stud? I fiddled with that one a little, and concluded that it may be easier to remove the whole steering linkage and swap it over as a unit, thus providing me with relatively fresh tie rod parts as well.
Originally posted by 91waggin View PostCheck out the Moog idler arm. It's a different, improved style than what came on the cars, and it has grease fittings. My steering is more sure of itself now.
Originally posted by Pirate View PostOh, just f---ing great, you're stripping shit off of my wagon.
Originally posted by Pirate View PostYeah, that was loads of fun going through several different idler arms before finding one that didn't begin flexing a week or two later....and of course, it was da' Moog unit.
BTW, what do you mean by "flexing"? :headscratch: Are you referring to undesirable movement of one or the other of the rubber bushings on the idler arm assembly, or was the metal arm itself bending?2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostAh, that would be what TOTCG was talking about when I talked to him on the phone over the weekend. I couldn't quite make sense of it because I'd put this thread temporarily from my mind. The idler arm I "stole" from what Pirate now informs me is his vehicle appears to be of a plain rubber-bushing design, with no grease provisions like that present on the pitman arm. Is there only one box-Vic idler arm offered by Moog, or would it be helpful for one of you gentlemen to post the relevant part number of the magical greasable idler arm you speak of?
So far as the Moog piece is concerned, if I can remember, I'll look up the NAPA part number for the high-quality piece, as our upper-end components are supposed to be manufactured by Moog.
Originally posted by 1987cp View PostSorry sir, I was not aware that this wagon was yours. When was it that you made me an offer to buy it? Is there a PM or phone message I missed?
