Curious to see if anyone here had fabbed up any kind of traction bar setup? I did a search but came up empty
Traction Bars Anyone?
Aren't those for leaf springs?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by mrltd View PostIt's a 4 link setup, you change the mounting points of the control arms to give more anti-squat. Traction bars are useless.
Now they are not necessary since our fenders are big enough to fit a very large tire under, but it will cut down on 60' times since the car isn't wasting as much energy squatting.
I was still able to pull a 1.8 60' on a mostly stock rear suspension, just Carrera circle track shocks, 97 PI springs in the rear with boxed control arms and a PI bar, was also running a 150#'s worth or rear wheel and tire. Front suspension is Competition Engineering 90/10 shocks, stock sedan springs and no front sway bar with a set of pro star skinnieshttp://secondhandracing.com/Home.aspx
