Might be a good time to go Big Brake Upgrade and '92+ SLA conversion for it's favorable camber gain and greater adjustment range.
Bushings...springs...shocks
bring it up phil
currently have two parts cars with civilian upper arms
have all the tools needed to do the job too
Ok since i did not want to thread jack Bowman's thread any more I figured I'd restart my thread here. My upper control arm "bushings" are shot. I just wanted to confirm (***ASSUMING THIS IS THE RIGHT PART***) that this would be the proper fix for it. http://www.energysuspensionparts.com...=MOOG%2DK8481#
I looked it up on several other websites and one did list my vehicle for an application, and the pictures from other websites also show exactly what mine look like. I would just like to confirm this to make sure it is what i need to replace. Then i will order them and make sure where i get them from has a good return policy!!!!
Heres the website that lists my application, and shows the correct pic i believe: http://shop.oreillyauto.com/ProductD...e=2060&PTSet=A-Phil
the oreilly pic looks to be stock civi shafts and rubber bushings. That would be one way to do your bushings, but at $100 a shaft, it would be cheaper to just snag a whole used civi upper arm, burn out the rubber bushings, and install poly bushings. NFC what that Moog thing is. It doesn't quite look like civi parts, but I don't know police cars nearly well enough to say its not a replacement for the solid bushing shaft.86 Lincoln Town Car (Galactica).
