is a c8 axel code the same as a c
axel code question "not on sticky"
Newer cars have different axle ratio codes. Helps a bunch if you mention the year of the car, or put it in your sig86 Lincoln Town Car (Galactica).
What year do the codes change?89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
Right... posting the vehicle info greatly helps.
axle codes started changing around 93, when the P71 coding started.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
