axel code question "not on sticky"
    is a c8 axel code the same as a c
    c8? Never heard of it. Sounds like 2 separate rears. A limited slip 2.47, and an open 2.73
      2.73 conventional for 98 + up
      found link in another post
      http://moldyrabbit.com/liquid/data.html
        Newer cars have different axle ratio codes. Helps a bunch if you mention the year of the car, or put it in your sig
          What year do the codes change?
            Right... posting the vehicle info greatly helps.
            axle codes started changing around 93, when the P71 coding started.
