View Post
New tires/wheels going on next weekend, last minute questions
Originally posted by Velvet Elvis View PostIf they aren't the correct backspacing they wont fit.... I hope you know the fitment, or test fitted them.
Originally posted by HotRodLincoln View Post
2= I found a really nice set of LSC Turbines with brand new tires for $200, and I was thinking of running those instead, because I think they would look a little bit classier on a Town Car. Thoughts, anyone?
Originally posted by John Deere Green View PostHe knows the LSC backspacing, ya goof!
I do remember reading that 3.75" was stock for a lot of RWD Chevys .... I had forgotten, but looking at the US Wheel website, they only list the 15x8 75 Series in 5 on 4.5" with 3.75" backspacing. Did okay on the 1" lowered Mercury with 255/60s, though. Could always just get a 245/60/15 ....2012 Mazda5 Touring | Finally working on the LTD again!
i have 275/60/15's on the back right now and 2.73 gears and it didn't change much performance wise. looks mean too. there about an inch taller over stock i believe. you would need between +6mm and + 25mm or so backspacing to clear alright... with wagon springs and truck shocks though. +6mm is perfectFinally have an on the books porting/custom fab business!
Originally posted by HotRodLincoln View PostI want to run 265x50R15 tires at all four corners2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostI have finally gotten around to beginning fitment tests using a pair of 265-50-15 Comp TAs I've had sitting around for a few years. The two rims in the attached pictures are identical US Wheel 75 Series in 15x8, 3.75" backspace, and the bald Radial TA shown for comparison is a 255-60-15.
What's your point? That size can still be had in something somewhat off-brand such as a Cooper Cobra or Mastercraft Avenger. There's a Hankook of some description also available in that size, I think. Not that I wouldn't personally much prefer one of these old V-rated Comp TAs, but if one were very strongly in favor of such a size, it can be had.
Perhaps more convenient would have been when you could still get a Radial TA in a 275/50/15, but I think that's been a while now. Of course, for an all-out effort that sees only limited street use, that size is available in drag radials of at least a couple of brands.
I had seemed to recall the 265/50 was available in the recent MT Sportsman ST street radials, but it appears that I had been mistaken.Last edited by 1987cp; 01-23-2010, 11:04 PM.2012 Mazda5 Touring | Finally working on the LTD again!
- Oct 2009
- 2878
- Keene NH
- Send PM
Ive got some P215/70/R15's and don't have any clearance issues, here is a pic.
The 265/50s are probably taller though."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
215 * .70 = 151.9mm sidewall.
265 * .50 = 132.5mm sidewall.
You sure the ones with the *shorter* sidewall are *taller* overall?2012 Mazda5 Touring | Finally working on the LTD again!
